Yes mate it was, unfortunately we never found out what moron did it.
But there's plenty of them about messing with Gas work, was on a site a few years ago where they had a "Gas fitter" doing a job. I was working in the kitchen when he was repairing a leaky compression joint, instead of useing thread seal he just ripped up a plastic carrier & wrapped a bit around the joint.
I don't like reporting people but I had to in this case, he was bloody lethal.
Your welcome Chris, I was the "Victim" shall we say of what appears to have been an unregistered Gas installer (Read also totally incompetent). A house that I was living in had a new meter installed, when the Meter installer did a pressure test on the system he found that there was a leak on the system so turned off the supply & told me to call a Gas fitter. Luckily a good friend of mine was is fully qualified & as it was at the time Corgi registered installer, he came straight over & we got down to looking for the Fault, 1st we found was on the heating boiler & was actually just a small leak because a joint had'nt been sealed properly. This though was nothing to the real fault, we found that the gas pipe for the Gas cooker had been run in the cavity wall & there were 2 joints that had actually never been soldered (Obviously no tests were done) & the cavity was filling with Gas, as they were ex Local authority & the cavity extended from 1 end of the row to the other the whole lot could have gone up. With all of us in it.
"Hello Again Specialist",
The kind of `Errors` that you wrote about are quite regularly found by either a VERY Dangerous situation occurring or by Qualified / Registered Gas Engineers / Installers when they go to a Home to carry out other Gas Work.
The FIRST thing that any Qualified Gas Engineer / Installer should do when going into any Building where they are going to do ANY `Gas Work` - which includes even a Visual Inspection of an Appliance is to carry out Tests from the Gas Meter to establish [or otherwise] that the Gas Meter and Pipework to the Appliances is NOT Leaking.
Then depending on what they are Contracted to do - The Appliances should be Checked for correct Installation and Safety of Operation.
At that point they can Notify the Client IF there is a Leak - Before they carry out ANY Work or Inspections / Servicing etc.
Otherwise they would carry out some Work or Inspections / Servicing and then `Find` that something is Leaking when they did their Gas Meter & Pipework Testing [If not done at the start] - Not knowing without Checking that it was NOT something that they had been Inspecting / Servicing.
And even then a Leak might have been caused for example by someone previously Overtightening a connection Nut - sometimes NOT easy to rectify correctly if on an Appliance !
Checking this and then having to Notify the Client that there is a Leak `On Existing Gas Pipework` AFTER they have done Work / Inspections / Servicing is NOT something that is to be recommended !
Regarding your example of the Pipework Joints that were not even Soldered - This is the reason that a Visual Inspection of ALL Joints on Gas Pipework at the point of Installation is VITAL - As the Flux that is used in the Soldering process can sometimes actually cause the Joint to `Hold` on a Test - while the Flux is in its `Paste` like form it can prevent Air / Gas from escaping as the Test Pressure is so Low - WHEN the Flux dries out GAS Leaks out !
Thanks for giving those examples of Dangerous Situations.
Chris
The mistake that you are all making in my estimation is to assume that everyone who passes some or other competency scheme is a "good engineer" and everyone who doesn't is a cowboy. I think that the schemes we have today are merely cowboy creation schemes where an unemployed window cleaner can become a certified gas fitter or electrician in 6 months or less provided they can afford it. I did an electrical apprenticeship in the late 60's early 70's plus 3 years of day release to qualify for Nat Dip in electrical engineering. I fix all electrical problems on my own gas boiler. If I have a gas problem, I call my gas safe man! or rather I did because he has now retired, so I have to find another one. You can be sure I will not be using any of the four gas safe registered cowboys who I got to "service" my boiler annually before I found him. I have the all important manual for my boiler, and I know how it should be annually serviced, with the first four guys it certainly wasn't. Being a cowboy is a state of mind which reveals a person who takes the shortest route to the maximum profit, and no amount of competency schemes will root him out. The vast majority of young supposedly qualified "tradesmen" I work with today are laughably incompetent to a man when it comes to anything other than a straightforward installation, fault finding? Forget it!! it bodes very badly for the future. The smart move seems to be to get into the training and registration "industry" QUICK!
If you maybe read the thread again you'll see that that's not what we're saying at all. In fact what I do know is that the 2 morons I mentioned were both as it was then Corgi registered. We're all well aware that there are Cowboys out there & a lot of them. The point still stands that servicing a Gas system / Appliance should'nt be undertaken by a DIY'er no matter how competent they think they are to do a repair & as Chris pointed out: Should there be a problem & a Court case then the DIY'er would'nt have a leg to stand on.
"Hello hermetic",
While I wholeheartedly Agree with most of your comments and I HATE the idea of People who have NO Association with Industries relating to Pipework or who have NO Technical Background being able to Purchase Training and Assessments in order to be Eligible to Register as `Gas Installers` - I wondered where I had `Been Mistaken` in something that I wrote on this subject ?
As I have written a few of the Posts on this subject - I wondered what You thought that I had written that was a `Mistake` ? - This is the comment that I refer to:
`The mistake that you are all making in my estimation is to assume that everyone who passes some or other competency scheme is a "good engineer" and everyone who doesn't is a cowboy`.
I certainly do NOT think that just `Passing` Assessments on Gas ACS makes a `Gas Engineer`.
In fact I think that the ACS should NOT be available to ANYONE who is not Training while Working for a Heating / Plumbing & Gas Company - and this should be a Company that would be Registered as a Training Provider `Partner` - Providing Training in conjunction with an Approved and Regulated Training Provider.
This would STOP the current situation where ANY Gas Safe Registered Engineer / Installer can `Verify` an Applicants Gas Work `Portfolio` - therefore enabling them to obtain the Gas Training and Assessment Places at the various Training and Assessment Providers.
I also believe that the Gas ACS should NOT be `Open Book` during the Assessments.
I am one of the Gas Engineers who HAS come from the Apprenticeship - [Plumbing] and `Continued Professional Development` in Heating and Gas Routes - plus the Defined Scope Electrical Part P Scheme.
The REASON that I keep mentioning the Gas ACS and Gas Safe Registration as being REQUIRED is because it is a LAW that ONLY those `Qualified` / `Deemed Competent` by Passing the necessary Gas ACS Assessments AND Registered with Gas Safe can LEGALLY Work on Gas Appliances / Gas Pipework etc.
BUT it is My opinion that the Gas ACS Scheme has Unleashed probably THOUSANDS of `Registered Gas Installers` who would not have anything like the Experience / Knowledge that I had when I was an Apprentice !
The Gas ACS were introduced to theoretically `Upgrade` the previous ACOPS [Approved Code of Practice] Scheme - as these were deemed to be `Even Easier` to Pass Assessment on !
Now they are viewed by the Government / Law / Training Providers as `At Least showing a Level of Competence` that requires Knowledge in order to Pass the Assessments.
While I personally would prefer that ONLY those who have completed an Apprenticeship which was either for Gas or included Gas Utilisation should be allowed to be `Registered Gas Engineers` / Legally allowed to Work with Gas / Gas Appliances - It was partly the Fact that there was a shortage of People doing Apprenticeships in Plumbing and Gas that required the `Dumbing Down` that saw the ACOPS and then the ACS being brought in as the Required Assessments for Gas Work.
Throughout My Career I have tried to Ensure that I obtained ALL of the Necessary Training and Examination / Assessments that were Associated with My Trade / Industry - `Continued Professional Development` - Too many to List here.
I view Myself as a `Consummate Professional` in Plumbing - Heating and Gas - My Career has spanned over 40 Years and I not only have the necessary Training and Qualifications / Assessments in ALL of the above Trades - but also Decades of Experience.
Chris
Well said Chris, I take your criticism, and agrre wholeheartedly.
"Hello hermetic",
Please don`t think that I was criticising You in any way - I was just asking you about what I wrote that made you think what you stated regarding `the mistake that We are all making` - words to that effect.
I also wanted to Explain further My `Beliefs` regarding the Gas ACS Scheme and its effect on the Registered Gas Engineer / Installer `Population`.
I was in no way trying to be Argumentative either - and I am `Guilty` of writing Posts that are VERY Long - I don`t do this because I particularly Enjoy Typing - as I can only Type with TWO Fingers - sometimes with only ONE ! - But as I am sure applies to many of Us I think of more details to write as I am Typing.
I was Pleased to read Your Reply to our Posts and as I wrote previously - I completely Agree with most of what You wrote.
Regards,
Chris
Got to agree with the comments about the state of industry and level of incompetent people being let loose in sparking and plumbing/gas sectors. Recent thread of conversations on a large domestic job I was on recently about part l & p etc " I`ve swapped f****ing loads of boilers me and I`ve never lagged bin told to lag f****ng pipes inside a house its warm!! "
ackbarthestar
Mentor
A Zoo near YOU
Website
https://www.leghrichardson.co.uk
United Kingdom
Heavily Qualified Electrician / Teacher / Tutor - etc
Heating systems and Gas- Electrical demarcation
Central Heating Systems
ackbarthestar,
ukiri,
