Heating Timer | on ElectriciansForums
Discuss Heating Timer in the UK Electrical Forum area at ElectriciansForums.net
jomac19b
Isle of Lewis
Hi. My heating and boiler are permanently staying on, even when my Horstmann control timer is set to off/auto on timer. Basically, the heating os staying on 24/7. All help appreciated.
Possibly a stuck motorised valve.
Find it on the pipework and give it a tap with a hammer to see if it releases.
If not, then you might need an electrician on site to test the system throughout to find the fault.
Expanding on the above a bit, assuming your system is anything like conventional, your controls (programmer, thermostats, etc) operate one or more electrically powered valves in your heating pipework. They do not control the boiler or pump directly.
The valves each contain a switch and it is this which controls the pump and boiler, so if the valve malfunctions it is possible for the boiler to be permanently on, or permanently off, whatever the programmer, etc are indicating.
The valves have a manual over ride lever on the side of the head, and moving this to the full 'on' position then releasing it to return on its spring can also sometimes dislodge a stuck switch.
Note that the 'head' of the valve can be replaced separately from the valve part.
P.S. Just noticed where you live. It's possible that there's a frost thermostat connected to your system, to prevent any chance of the water in the pipework or boiler from freezing. If so, it may just be doing its job, wit nothing wrong.
Reply to Heating Timer in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Thanks for the reply,I too had forgotten about this.... I'm not sure about going for the halo now as the halo app has not had very good reviews ie...
