Heating wiring advice please
Don’t be put off or daunted by heating they are a piece of p**s once you understand what you are trying to achieve, the system you show above I.e hot water, heating(rads) and underfloor heating and External oil fired boiler
Isn’t as complex as you’d think.
The UFH as said earlier will have its own wiring centre for the pump the stat or stats I presume with having four zones you’ll have four stats and at least four actuators the connection of this is simple with the fully labelled wiring centre supplied.
In effect you have three switched lives to fire a boiler each passing through stats which in turn open a valve which supplied a switch live to the boiler. Simplest way is a two channel clock heating got water and programmable room stats for each of the UHF zones. Sorry if this sounds a bit long winded but as I say a lot easier than you’d expect as said before quiet place few diagrams and no worries.
This has raised an interesting point; hope I'm not off-topic. I'm Level two with a couple of years site time heading to Level Three. What's the best way to get to grips with heating wiring? I understand how boiler pumps etc interact and I can read the S and Y but, as has been said many times in here, this does not a skilled Sparky make. What's your thoughts ladies and gents?
Honeywell do some excellent courses on the subject. You’ll find them on their web site.
Just learn the colours of the valves and what they do and the sequence of switching then all will become clear.
Two port valve.... Grey perm live, brown switch live from controls, blue neutral, green and yellow earth and orange switch live to boiler and pump..unless the boiler has pump over run then the pump is connected to the pump live terminal in the boiler.
Order of sequence/switching.... programmer, thermostat, valve, boiler and pump.
Say this is for the CH....CH on connects to common of room thermostat, switch live from thermostat connects to brown of the valve and orange of the valve connects to switch live of the boiler.
It's just a load of switching in series.
