Heating wiring advice | Page 3 | on ElectriciansForums
Discuss Heating wiring advice in the UK Electrical Forum area at ElectriciansForums.net
Pauly
Nottingham
I have wired a heating system with 8 heating control zone valves and 1 on water,all work ok,problem is it has heating pump which comes on with heating valves but also with hot water zone valve,how can I separate the heating pump to only come on with the 8 valves.
Hi mate I'm not to hot on the plumbing side of heating systems but there are bypass loops in front of each secondary pump so they won't be able to pump against nothing and there is a loop for the boiler as well
Reply to Heating wiring advice in the UK Electrical Forum area at ElectriciansForums.net
B
Replace central heating gate valve with 2-port valve My house has a separate central heating loop that heats an annex. The annex loop has 3 x...
Barnjet
B
Update... I wired up my first heating system today! Thanks to all the help in this thread, (and the initial thread) I was completely prepared...
