HELLO! How to know how much you uk socket can take? | on ElectriciansForums
Discuss HELLO! How to know how much you uk socket can take? in the The Welcome Forum area at ElectriciansForums.net
MrC123
United kingdom
pretty self explanatory, just need to know how many watts I can pull from each plug as I'm going to be using a fair amount on extension leads.
Are you not limited by the fuse in the extension lead plug?
What are you going to be plugging in?
Well....each extension lead is limited to a maximum of 13amps, so the maximum you'll be able to physically pull would be a (nominal) limit of 26amps.
IIRC the test spec for BS1363 double sockets is that they should be able to handle a constant total load of 20amps.
I do not have a current ( :) ) copy of BS1363. But the 1995 version said this and i do not think that things have changed:
13A double socket rating to BS1363
BS1363-2:1995 requires for double socket outlets that both socket outlets have loads applied via test plugs, 1 test plug having a load of 14 amps whilst the other has a load of 6 amps, making a total load of 20 amps on the cable supplying the double socket outlet. The double socket outlet is then subjected to this loading for a minimum continuous period of 4 hours or longer until stability is reached with a maximum duration of 8 hours (stability being taken as less than 1 degC rise within 1 h). The test is passed if neither the terminals / terminations, nor the accessible external surface, increase in temperature by more than 52 degC.
I may be able to advise more if you can say exactly are you planning to plug in to these "fair amount of extension leads". and why are so many required?
Just a small correction @Taylortwocities. His quote is "...I'm going to be using a fair amount on extension leads"
I presume he is going to be plugging lots of things into a few extension leads... We will have to wait and see what the OP's reply is.
Power =Volts time Amps the max Amps would be 13 A governed by the 13 A fuse in the plug top times the voltage 240 Volts
As I put in #post 2 mate.
Reply to HELLO! How to know how much you uk socket can take? in the The Welcome Forum area at ElectriciansForums.net
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
