HELLO! How to know how much you uk socket can take? | Page 2 | on ElectriciansForums
Discuss HELLO! How to know how much you uk socket can take? in the The Welcome Forum area at ElectriciansForums.net
Doesn't really matter as it seems the OP has done a runner....
Yes, to turn that into the load that the BS1363 socket is tested to carry, the maximum load would be 4800watts.
Anyway, got a busy day today. Market in town, getting all Christmassy!
Oxford is made for Christmas:) ...just have to sell a property,to afford to park...;)
Well....each extension lead is limited to a maximum of 13amps...
IIRC the test spec for BS1363 double sockets is that they should be able to handle a constant total load of 20amps.
Completely agree! While most socket-outlets are rated 20A, the plug-top fuse will be limited to a maximum of 13A (approximately 3kW).
13 a plug @ 240v = 3120w.
Remember that according the the ESQCR, the voltage used in calculations is 230V rather than 240V. We use 230V because current is inversely-proportional to voltage when maintaining the same power (in Watts); as the voltage decreases, the current increases proportionally. In practical terms, this means that while maintaining the same power-consumption, if the voltage is grater than 230V (which is common) the current will decrease which results in lower temperatures in the conductors (which is safer).
Therefore:
230V x 13A = 2990W
yeah? i thought it was because we wanted to be like the french.. :D
No mate it was the EU that told us we had to be like the French, a big difference. We saved their backsides 70 odd years ago, and now they're telling us what to do, something wrong somewhere along the lines.
i seem to remember back in the 90's the IEE as was then , made the wiring regs into a "British Standard" ( 7671) so that Johnny Foreigner could not interfere. worked well, since then we've had 230V and stupid cable colours stuffed down our throats. well done the IEE.
I think you misunderstand. The 20A test current is the sum of the currents through both sides of a double socket.
If you plug an extension lead into each socket on a double socket out let, the fuses in each extension lead will limit the amount of current that can be drawn.
So each lead will have a 13 Amp fuse (r should have) so 2.99 KW can be drawn from each outlet, via one extension lead, or have I missed the point?
No you haven't. But that total of 2x2.99KW exceeds the design spec as laid out in BS1363.
That's why it is important to know what our (now long unresponsive) OP is planning to plug in to the extension leads.
His view of
going to be using a fair amount
May not be so much in amperage terms, In my experience our average DIYer wrings his hands at the thought of plugging in a PC, printer, router and a 2TB disc into an extension lead, but will not even think about the implications of a washing machine + a tumble dryer in the same extension or socket.
I wait with ever increasingly bated breath - in the hope that we may learn of the application - but I fear that turkey, pudding, cheese and glasses of Portugal's finest may make me lose interest altogether.
His view of
A total of 26 Amps from a double socket then?
Reply to HELLO! How to know how much you uk socket can take? in the The Welcome Forum area at ElectriciansForums.net
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
