hello...new here.....earthing of protective material to kill wifi in van...…..?? | on ElectriciansForums
Discuss hello...new here.....earthing of protective material to kill wifi in van...…..?? in the Auto Electrician Forum area at ElectriciansForums.net
Geomcn
Crawley
helloo peeps.....new guy on the block...
I have a tracker in my van which also has a dastardly wifi at 2.43 ghz in it. it is on 24 hrs a day.
It is now beginning to show symptoms which are painful - sometimes my left eye hurts as I am driving.
it is in the glove compartment of my berlingo.
I want to shroud ''my side'' of the van with a wave blocking material and then earth the material with a crocodile clip and a cable on the clip. can I do this by attaching the cable to the neutral point on the battery ? if so, how do I get the cable through the bodywork.
thanks in advance - also ,pls, no wisecracks about tin foil hats - I have heard all that crap before .example : john McCain, usa senator, died of an ipsilateral glioblastoma , brain cancer on the same side as the mobile, caused by obsessional use of his mobile >> AKA ''electromagnetic waves killed him''
thanks! georgio
My cure for my left eye ,was to wear a cap on sunny days.
(did find sun shading from Left hand side -Hard work)
If you can find electro-static screened sunglasses that ,may help.
(also check air vent directions - we all become more succectable to drafts , dry-eye,pollen irritation)
I've had 2W of 27MHz rf warm my ears before now .
( My mates may disagree with any signs of my brain injury. )
... Not all of your symptoms may be down to 500mW ...
In all honesty there is absolutely no proof that this is the case. I'd be going to the doctor for a proper diagnosis. Otherwise this is probably just a placebo.
hi Matt - you may be an electrician , but I am betting you have no education in bioelectromagnetics, the study of electromagnetic waves and their effects on humanity - and all other species on the planet.
In all honesty - I have no proof that you know or understand anything at all on this subject - but you are determined to tell yourself that the waves are safe?
For what reason?
I certainly won't buy it, for one.
next thing is aliens in the attic, comuing to get us and assimilate us into the collective.
For what reason?
Ok mate. Good luck making your tin foil space suit. Hopefully the phone doesn't cause your head to explode :)
I agree with telectrix, why would you put your left eye in the glovebox?
It's for your left hand complete with covering!
thanks! georgio
What proof is there that this was caused by use of his mobile phone?
Has a study been carried out to compare instances of this brain cancer in the left or right side of a brain against which side the patient tended to use their phone?
Your best bet with the tracker would be to switch it off whilst driving if it is intended to aid recovery of the vehicle if it is stolen. Or to replace it with a tracker which doesn't have the WiFi.
Anything you install to shield the drivers side of the van from the passengers side which effectively screens RF will partially obscure your vision out of the van whilst driving which is illegal and dangerous.
[automerge]1583087259[/automerge]
For what reason?
And you are determined to tell yourself that the waves are unsafe, we also have no evidence or proof of the ideas you have presented here.
If a mobile phone can increase the chances of cancer developing would it not be more logical that the increase woukd be in cancers in the leg, -------- etc would increase also as phones usually spend more time in people's pockets than against there heads?
If it’s causing health issues, don’t cover it with something, just disconnect it
I had heard about this wifi health hazard but never, until now, came across anyone believing it.
There is apparently zero scientific evidence to point to a health hazard but as is normal with these things that is almost irrelevant to those who choose to believe it.
Reply to hello...new here.....earthing of protective material to kill wifi in van...…..?? in the Auto Electrician Forum area at ElectriciansForums.net
