Currently reading:
hello plss help it will take 2 sec.
Discuss hello plss help it will take 2 sec. in the Home Media Centre Forum area at ElectriciansForums.net
hello everyone i want to change my Xbox one adapter from 110V to 220V i watch video and there is 1 part needed part name is: HEL 14D 471K. so my question is: that module and (NU) 472M X1Y2 is same ? i mean can i use this instead of showed in video ?
p.s. i'm 2/10 at knowledge of electronics.
sorry but i prefer to transform it. i'm sure it will work just need to know if this 2 do same thing.
thx anyway for sugges.
i cant reply it says i am spamming or something like that :(
If you make 5 posts to the forum, you will avoid the spam detector then. It is set quite high for the moment while I get some data to tweak it. New forum upgrade recently. ???
As above mate. It would probably be cheaper to the the above power supply.
So to answer your question regarding the varistors:
HEL 14D 471K spec:
I can't seem to find a spec for the (NU) 472M X1Y2.
(NU) 472M X1Y2. Sounds like a reforming safety capacitor.
This stuff may just be at input.
(More important part is if part converting power has
2x 120V Parallel or series bits. )
(You are moving in the more dangerous direction -Need experience )
Reply to hello plss help it will take 2 sec. in the Home Media Centre Forum area at ElectriciansForums.net
