HELLO | on ElectriciansForums
Discuss HELLO in the USA Electrical Forum area at ElectriciansForums.net
behind a pine tree,with a scope on you
Hello sparkies
I have stopped by because i have a slight problem in my house.
I am a master plumber, I have worked with you guys for years,
I hope you would be so kind as to steer me in the right direction.
when my AC kicks on, my lights blink.
From what I know, that aint good.
I have a 200 amp service so that is not the problem
any guesses as to wth is up?
[ElectriciansForums.net] HELLO
Hello sparkies
If I have to guess
Hello sparkies
Hello sparkies
If I had to guess I would say there is a loose connection, I don’t what size unit you
Ok..I will check the breaker box. tighten up the connections and report back tomorrow around the same time
thanks man.
frod you be careful and turn off breakers while checking
Hello sparkies
Is the wiring to the A.C sized correcrly? sounds like you may have a Volt drop problem in your House
Reply to HELLO in the USA Electrical Forum area at ElectriciansForums.net
P
water pressure problem, unvented system I'm trying to sort out a problem with low water pressure at my elderly parent's house where they have an...
plomero
P
M
What is causing water hammer in my flat? Hello I wonder can anyone shed any light on what is becoming an annoying problem? I had a new stopcock...
Mr Gwent
M
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
