SPARK2B
Hi all, I am soon to start my 204 practical element of the 2365, most of you have probably already completed it, but i am guessing that some of you will not have dont it yet.
i hope the picture uploaded is of acceptable quality and size.
tray, trunking, pvc and conduit is already built
installation contains
a ring final containing 3x socket outlets and one fused connection unit (going through trunking and steel conduit
a radial wired in swa to supply a bs en 60309 socket outlet
lighting circuit in the pvc containing 2 x two way switches
bond gas and water pipework with a continuous conductor of the correct size
test the installation.
now im after some advice on the best way to attack this installation, and hints and tips, what to do first, make life easier etc etc that may be out there for it from both trainees and of course the guys running the forum!!
any and all help much appreciated,.....as always!! and thanks to matty for advice already given!
SPARK2B
SPARK2B
