flukey
thought a bathroom was a special location irrespective of zonesI doubt it's a special location if it's downlighters, unless he has very low ceilings.....
Discuss Help before I set fire to my house please? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
We all want to be approved advisers!!!!!!!!
I had better start behaving!
On the oversize hole, cant believe I did it the other day, picked up the usual hole cutter, drilled me holes, I measured 3 times, lazered a perfect line then drilled 8 off 86mm holes instead of 76 mm holes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Had to go out and buy different lamps!!!!!!
I wouldn't notify out of zones I don't think. Probably wrong, but hey, it's a moot point anyway.
its the bathroom thats the special location so if the lights are in the bathroom, whether in or out of the zones they are still in a special locationHmmm I've always assumed that if not in a zone, then by default it's not a special.
Not that it makes much difference as I always notify via elecsa, but if I was going down the LABC route, I wouldn't notify out of zones I don't think. Probably wrong, but hey, it's a moot point anyway.
So where does your exclusion from notifying start on external locations, which again are special according to Part P?
This reg does not quote zones so to me the whole room is a special location.
I wouldn't do anything in a bathroom proper without an RCD.....
Anything?!
Reply to Help before I set fire to my house please? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
