View the thread, titled "Help. Boiler leaking (heater exchanger connection)" which is posted in Central Heating Systems on Electricians Forums.
Does anyone know why water is leaking on that connection. Vaillant ecomax 824/2 E, It's heater exchanging connection, the one which is secured by the clamp (there is no rubber seal? -how does this even works ??) Screenshot_20250305-205205_Chrome.jpg20250303_112711.jpg
Seems to be a common problem, as you'll see if you search on Plumbers Forum.
Used to be a black rubber pipe, now a copper pipe.
There are (supposed to be) o-rings on the HEX spigots, apart from the one with a packing ring connection
The suggestions below relate to using a jubilee clip on the old rubber hose to improve the seal. Maybe a replacement o-ring would do it, given you have the copper pipe?
Reply to the thread, titled "Help. Boiler leaking (heater exchanger connection)" which is posted in Central Heating Systems on Electricians Forums.
