Z
Zaby
Hello.
Can I ask for some expert advice please.
I replaced an old 7.5kw shower in my upstairs bathroom with a new Creda 9.5kw last year. I understood that this was acceptable under Scottish regs. After a few months of good operation the pullcord switch fused, and I replaced it. After this, the RCD started to trip once or twice a week, when the shower was used for more than 10 minutes. The RCD then started to trip more regularly, and then every time the shower was on for more than 10 minutes.
On checking the tripped RCD it was very hot, and at that point I knew something was wrong. In retrospect I now know that I measured the cable wrongly, and I have 6mm cable, not 10mm!
So, I urgently changed the shower for a 8.5kw. So at this point I now have an 8.5kw shower, on 6mm cable, with a 45 amp RCD, which I believe is acceptable.
The RBD does not get nearly as hot, but it's now began tripping again after a long shower.
My feeling is that I have been running a dangerous combo of 9.5kw on 6mm for so long, that the RCD is now degraded, and will continue to trip regularly??? Can anyone advise what I should do? Should I buy a new RCD? Is this an acceptable system? I simply can't afford to get an electrician in to change cables, and the bathroom has just been retitled.
Thanks for your replies.
