L
lawrenso
Hi,
bought these powerstrips (http://www.eubiq.com/assets/pdf/installationmanual/SC.pdf) to be fitted in our kitchen that has nearly finished a refit. Showed our electrician and he was happy with them - so had wiring all done and re-run with cable (ring man twin and earth 2.5mm) coming out of holes in the tiles. Well, now he has tried fitting them and they won't go because the cable is not flexible enough.
These units have a plastic clip on plate that is screwed to the wall and then the powerstrip clips onto this. The rear entry at one end has a cable strain relief as per on a plug etc... and the instructions actually show using 3 core for wiring them up but he is adament that 2.5mm has to be used - even though the cable is a spur coming off a fused box on a ring main, coming down the wall behind the cabinets and down behind some tiles and coming out of the tiles for connecting to
I believe that, because of the fused spur, that a flexible cable such as a 1.5mm multi-core can be used instead of the 2.5mm twin and earth, however, he has said no (from his supervisor who hasn't stepped near or seen them) - who is right and who is wrong??
answers quickly please before we have to take cabinets down and smash some tiles off and put in ordinary sockets with all the work that entails
Cheers
Lawrenso
Cheers
Lawrenso
