Help finding fault after a short Circuit( Com with Neutral ) | Page 2 | on ElectriciansForums
Discuss Help finding fault after a short Circuit( Com with Neutral ) in the UK Electrical Forum area at ElectriciansForums.net
Spelyam
London
Hi there
Im reaching out here as I have given up trying and couldn't find a local electrician to help today .
so the issue .
after painting the wall I was try to fit the light switch back into the wall and somehow the com cable touched the metal surround on the wall.
the lighting RCBO tripped so i turned it on but the lights didn't come on . this RCBO controls all the lights in the house however the kitchen , bedroom and living lights still works , Bathroom and Hall way are down .
the short happened on the bathroom light switch .
I have actually swapped the RCBO with a new one but only to get the same issue .
im not sure what to do next as i cant find another splitter or anything else i can look at . any help would be soooo appreciated .
located in St albans AL2.
thanks
YAman
[ElectriciansForums.net] Help finding fault after a short  Circuit( Com with Neutral )
its crazy lol , i ve got an electrician coming tomorrow but this doesn't make sense . ive checked the other switch in the same circuit and reconnected everything to make sure all is closed with the same issue .
could this be maybe because i used the incorrect RCBO ?
[ElectriciansForums.net] Help finding fault after a short  Circuit( Com with Neutral ) [ElectriciansForums.net] Help finding fault after a short  Circuit( Com with Neutral )
[automerge]1570292273[/automerge]
also just relooking at the RCBO old one says B6 and the new C6 ?
FINALY !
right ,
The lights were daisy chained and the Electrician that came confirmed that .
after a whole bunch of tests , he said that when I sparked the light a live wire feed must of came loose at a junction somewhere. nothing to do with the RCBO.
so we figured that is starts with the living room , then bed room then kitchen then hall way and ending at the toilet ( 1 bed flat ) ( not tested but just logically thinking )
It should be at one end of a light before the hall way which was the kitchen.
before we got to the kitchen we decided to check the ceiling light at the hall way and there was a bunch of connections and one of them was loose ! tightened everything there flicked the switch and it all worked.
it amazing to watch a craftsman do his work ! learned a bit as well .
thank you all for the help
Reply to Help finding fault after a short Circuit( Com with Neutral ) in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Thanks very much for your help chaps. It turned out to be reversed polarity and some dodgy DIY stuff. I'll go back another day to sort it...
