Help fixing 2-way ceiling switch | Page 2 | on ElectriciansForums
Discuss Help fixing 2-way ceiling switch in the Australia area at ElectriciansForums.net
post deleted
Strange.
Here is my thinking on what the wires are.
1 of the red wires is your permanent live to the switch.
The other red wire is your feed to the light.
So red wires should go either side of switch. (1 in common, 1 in L1).
The brown (as I would wire it) is the permanent feed to the fan (connected together with your permanent live in the common) and the grey would be the switched feed to the fan (connected together with your feed to the light in L1).
Are you sure both red wires are in properly?
working perfectly :) Thanks so much, light and fan. I switched the grey and brown over and both ways the fan just turns off with the light but to be honest I can't really remember it staying on previously. Thanks so much for all your help, made my day!
Reply to Help fixing 2-way ceiling switch in the Australia area at ElectriciansForums.net
Ha.had a whole school corridor like that when I was an apprentice ,was only changing type of fitting .nightmare .couldn't work out why there was...
Hello freddo (and everyone else who commented!), Thanks for your comment. Using that info, I now have this on the main: and this on the...
