Help for Submain needed please. | Page 2 | on ElectriciansForums
Discuss Help for Submain needed please. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am planning to install a 2 WAY CU in my garage that will feed 1 lighting point and 1 double socket. I am planning to feed the CU 2 in the garage from my CU in the house, from a B20 MCB using SWA 2.5mm. I want to know if I can take the SWA form the CU through the external wall and run it along the wall externally to the garage CU 2 . Is this ok. Any advice or a better alternative would be greatly appreciated. Cheers Derry0178.
if you are feeding SWA through a wall, drill at an appropriate angle so that the SWA comes out of the wall without you having to make a tight bend. hope you can see what i mean. ( oh, and don't praise trev too much. he'll get big-headed. :44:)
That's a good point, didn't think off that. Will do, I will drill through as you say, Nice one! Cheers Derry0178.
If you can ,Drill from outside in .You can make good the plaster on inside but a blown out brick on the out side will look messy.
How are you going to terminate The SWA into the CU ?
I was going to terminate the same size (6mm) but in Twin and earth to the House CU as it is plastic, and run the twin and earth to a metal enclosure, and take the SWA from near, using a banjo and crimped CPC. Looking into what metal enclosure box to use, any ideas. Cheers Derry.
You could use a 25mm metal conduit end box on the outside of the house (outlet facing down) make off the SWA into that with a water proof gland and then run the cable inner sleeving still on though the wall into the back of the CU you will have to run an earth lead to the conduit box though (USE 3 core swa)
Great point "not clever" but you can't rcbo the house and put a RCD socket in garage as its against regs, can't have 2 30ma RCDs in series, plus you won't need rcbo in house as its swa.
like you said RCD socket in garage but instead of FCU use the 1G RCD module instead to control the lights with a 5A fuse installed.
Think you'll find it didn't say use rcbo and RCD sockets in series at all, I said .......rcbo and bog standard sockets.
Swa or not if standard sockets are used an rcbo or RCD will be required at the house.
if i were to do it that way, i'd chuck a piece of pvc tube through the wall.
Reply to Help for Submain needed please. in the UK Electrical Forum area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
