Help ideas on moving a main Incomer | on ElectriciansForums
Discuss Help ideas on moving a main Incomer in the UK Electrical Forum area at ElectriciansForums.net
smity
Hi guys,
I have just picked up the keys to my new house, the Incomer is exposed under the stairs and looks a mess, I will be doing a gradual rewire as we revamp the house over time but firstly I will be sticking a new CU on.
Now if you look at the pics what would you guys do with this? I want it hiding or moving so my daughter can't get near it.
It is on an external wall, would it be possible to have it moved to an outside box? Or am I just going to have to squash it all together as best I can then box in?
Any ideas would be much appreciated
[ElectriciansForums.net] Help ideas on moving a main Incomer
You're not supposed to touch the incomer mate. It's not your toy to play with and it'll be very expensive to get it shifted. Think about boxing it in, it'll be a hell of a lot cheaper and quicker.
I know it's not my toy to play with mate I was talking about having it moved by the DNO as its in a **** place.
I had a feeling that they could be moved within 3m for nothing but maybe wrong
Cheers
not easier just box up whole lot? make a door for those shelves? if you really want it moved then got to contact your electricity provider, they can do it, and it may be not cheap. supply cables do not like to be disturbed...
I want to hide it as best as possible as I don't want my 2 year old daughter sticking her fingers in it. Maybe moving it outside was a little bit optimistic but there is some length on the supply cable swooping along the skirting board and it looks a mess and thought they could come and move it all into one corner which I could box but seems I will just have to keep it where it is and box in then.
I was just hoping for some ideas from guys that do domestic day in day out as I don't.
Ok.
1. Don't mess with it yourself
2. Contact UK PN
Hi, I'm just about to have mine moved from inside to an outside box, by Western Power, and the estimate is ÂŁ750 (incl VAT) with me digging the trench and bricking in the box
There is a good guide to the process on their website interesting to read even if they are not your supplier.
Downloadable from this page:- Western Power Distribution - Service alterations
Just what I was after, thank you very much for your useful and non condescending reply [emoji6]
It's not cheap but maybe an option in the future as its in a bit of a rubbish place at the moment. But I may have to just make a cabinet again
Reply to Help ideas on moving a main Incomer in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
