Discuss Help, I’m sure someone can answer this very quickly in the DIY Electrical Advice area at ElectriciansForums.net
Thank you ??The three browns in the block connector keep separate and not connected to the light. Two blues into N, the blue with the brown sleeve into L and the green/yellow sleeved ones into the middle terminal between N and L.
Reply to Help, I’m sure someone can answer this very quickly in the DIY Electrical Advice area at ElectriciansForums.net
