Help! Is this wiring correct? | Page 2 | on ElectriciansForums
Discuss Help! Is this wiring correct? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Have the builders supplied the electrician?
If so ask the contractor what he thinks or ask th electrician himself.
Yes this is wrong.
Worryingly if this is wrong what else is wrong?
Ask if he is qualified and registered. Get proof.
Possibly get another spark in to check or if building control is involved ask them for a visit. They will know.
Not ideal I know, but you don’t want the project finished to find it then needs putting right.
Hi all, so it looks like I made a huge mistake. The grey cable actually has a brown and blue wire coming out of it and a copper wire in between (the earth wire I believe). I was looking at an old cable. So sorry.
The green/yellow earth wire in the photo is attached to and comes with the light fitting. The tape that can been seen around the cable is holding two cables together as opposed to a joint.
Hopefully this means that the electrician is using the correct cable.
One other thing I forgot to check was the width of the grey cable as I’ve heard that it should be different for lights and sockets (1.5/2.5mm) although I’m not sure why.
The lighting circuit is usually protected by a 6A breaker, therefore 1mm or 1.5mm is fine.
The socket circuit is usually protected by a 32A breaker, therefore 2.5mm or 4mm is fine, depending on circuit type.
Of course but I wanted to understand whether I was right/wrong/clarify before approaching him. I wasn’t going behind his back, just wanted to be more sure of my concerns before speaking/confronting him.
It’s fine to ask. You just wanted a second opinion. You got third, fourth, twelfth all at once.
What sort of downlights use those brackets? I presume they get buried in plaster then the light is fitted after decoration?
Do plasterers like these things? How easy is it for them compared to just a hole to spread around?
I measure where any obstruction is, and drill a clean hole afterwards avoiding any joists.
Top tip I was taught once: drill pilot hole first, stick a wire coat hanger up and spin 360 degrees to final check for joists :)
Yes they are plaster over lights. I am told (by the lighting shop) that plasters love them especially as the lip gives them a guide as to thickness of skim.
Reply to Help! Is this wiring correct? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If the OP could DM you with that info? Rough area is fine, but don’t post your full address in public, obviously.
Brilliant. Thanks Brian much appreciate the advice.
