Help.. Light Bulbs Blow When Switched On | Page 2 | on ElectriciansForums
Discuss Help.. Light Bulbs Blow When Switched On in the Lighting Forum area at ElectriciansForums.net
My opinion, without seeing anything, is that the high supply voltage is the problem.
It's not likely to be outside of the limit (253V) - but it is feasible and if verified as outside the limit, the DNO should investigate and take remedial action.
The reason lamps blow at switch-on is that (particularly with halogens) the filament has a much lower resistance when cold.
So, at the instant of switch-on, a large current flows which results in a large magnetic field around the delicate filament. It twangs violently, snapping at the weakest point.
Obviously, with a higher than normal supply voltage, the current will be higher.
Then, the resulting arc ionises the gas in the lamp - so the lamp then appears as a short circuit, the fault current causing the MCB to trip (and destroy your dimmer).
I'm generally up in Cleethorpes a lot, but don't think I'll be there in the next week or so... though I have a heating install to do on a holiday home up there in the near future.
Simon.
Reply to Help.. Light Bulbs Blow When Switched On in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Sadly not very near Swindon! I'm in Oswestry. Thanks a lot for the thought though!
Requirement or not, I've not installed a domestic lighting circuit without RCD protection for double that.
