Hey guys
As some of you know I study at York College. I am working on an assignment exam, Which I need some help with.
Fixed appliances:
Building construction :
This is for a 2 bedroom bunglow and I need to wire it.
I have decided the accessories will include the below and with FSU for boiler, and cooker:
2 bedrooms –ill put 1 x light in each room. And 3 x double sockets each room
1 onsuite room – so 1x light – no sockets
Small hallway – 1 xlight and 1 double socket and 1 smoke alarm
Bathroom has sections so 2x lights. 0 sockets
Utlity room – 1 x light plus 2 x double sockets
Kitchen 1 xlight. Plus about 7 xdouble sockets and 2 x single sockets.
Large diner and lounge room integrated.. so therefore 2 x lights plus 5 x double sockets
If you think I should add more please let me know.
What will be the best way to wire this ? since theres concrete under laminated flooring, . I am thinking of taking the cables from the consumer unit and take the wire up to the loft clip to joists and drop to the nearest socket for the circuit and then back up the wall clip up the joist and come down again into the next socket. And repeat until the sockets are complete. For the ring curcuits. Take the wire back again same way
In terms of lights can I just lay them over the plastboard? And it doesn’t matter how they go as theres no safe zone etc. is this correct? So in affect I can just go up the consumer unit abover th plasterboard just go in diagnels if I have to get the light and switches?
once Ive done this I will do all the calcs required.
Any advice would be greatly applreciated. I am more than happy to discuss further,.
thanks
Fixed appliances:
- 12k W electric cooker with induction hub (no socket)
- 300W extractor over cooker
- 7 KW electrical central heating and hot water boiler.
- Outer walls - brick with wood cladding, insulated cavity
- Inner walls : plasterboard dot and dabbed onto lightweight blockwork
- Floors: laminate flooring on 50mm concrete seed.
- Ceiling
lasterboarded through with acess hatch into fully accessible loft void above. Ceiling 2.3m above finished floor level.
- Loft insulation : this 250mm thick and cables are to be clipped to joist or lay on plasterboard.
- 230v , TNCS, with ZE and PFC at 0.3 ohms and 0.77ka
- Amb temp 25 degrees
thanks
