P
Phil Griffiths
hello just couple questions regarding my my design exams..
1. A 230V single phase circuit is protected by a circuit breaker with RCD (RCBO). justify witch component part of the device would operate for the following faults ..
a. line to earth fault 2.3 ohms
b. line to neutral fault 0.01 ohms
c. neutral to earth fault negligible impedance
d. an overload approx twice the nominal rating of the device
any idea how to work these out!? if so your help would be much appricated and please could your show me how you did it thanks very much
