View the thread, titled "help needed guys please regarding inverter choice" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
thanks guys - i will stuck with the 3.6 OUTD over the PVI-3600 although the match is not perfect -
got to get it right this time mate - its been on going since Nov 22 nd - in that time I've only generated 159.1 on my gen meter
Ok guys
An update to this - new inverter fitted PVI-3.6-OUTD. But this won't connect to my new aurora desktop monitor . The radio card has been fitted but the unit will not pick up a signal.
Just browsing through manual and it says it doesn't work with the OUTD model.
Looking on the power one website for the monitor support page, the installer video shows the guy connecting it up to an OUTD model
Has anyone got this combo working? Or am I in for another fight with the installer for a refund. I've tried a firmware update. On the side of the unit it self it says PVI-DESKTOP-IT. But has a UK sticker stuck on it. (I'm assuming it's been converted from Italian to uk stock?)
Any answers for me guys- once again thanks in advance
I have fitted a couple of wireless cards to PVI-3.0-OUTD inverters without a problem. The 3.6 model should work equally well.
Sorry if I am teaching you to suck eggs, but the frequency at which the wireless link operates means it is line of sight and does not like going through thick masonary walls or foil lined walls. A few tips:
- get the connection working with the desktop beside the inverter, before moving it further away.
- I do not have the instructions in front of me, but I recall there is a litle lever on the card to reset the wireless card.
- the external aerial on the inverter can be rotated: try it vertical, horizontal and at 45 degrees and rotate in the horizontal plane to see which give the strongest signal at the desktop device.
Thanks for the quick reply - the installer had the unit in the attic with him. He'd never done one before with the radio card installed .
Reply to the thread, titled "help needed guys please regarding inverter choice" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
