Help needed, is this correct? | on ElectriciansForums
Discuss Help needed, is this correct? in the The Welcome Forum area at ElectriciansForums.net
ASH77
stockton
I have a two 32mcb in the c/u. I thought one would be for the upstairs sockets and one would be for the downstairs sockets but they are not.
both require switching off to cut off power off to both upstairs and downstairs sockets!! is something wrong with this?
each 32mcb has only one live exiting, surely you cant have a ring circuit from one mcb to another, it should exit and return to the same mcb, shouldn't it?
Could be they’ve split it front to back....had that a few times on old terraced houses...
Edit....sorry just read the post properly ignore me
I did an EICR on a large house last year .......... all the 32A breakers had 2 cores ............ unfortunately, none of them were paired correctly :(
get an electrician in to see what is going on, from first appearances, this is both wrong and under overload conditions could be potentially dangerous.
Sometimes you will get legs going to feed upstairs then en route they drop down in a chase to downstairs sockets.
Best way is with a plug in tester, switch one MCB off and mark which sockets are off with that one, then do the same with the other.
Mark it on the socket or on an A4 sheet and stick it with the consumer unit.
It’s the way it is sometimes.
did you read the OP?;)
Reply to Help needed, is this correct? in the The Welcome Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
