Deleted member 114336
hi
My housemate uses too much electricity- constant heater etc- I want to separate our electricity readings.
What can I do pls?
P.S. I’ve looked at smart meters on individual sockets however he’s got lots of sockets in his room and would find a way around them.
Reselling electricity has strict rules as far as I know, you can only add a small amount to cover 'maintenance'. Although your solution is good and perfectly acceptable to any decent person I fear in this case that the same coin would get endless use. :rolleyes:
Sealed meter, my Mum had the same set up so I know it well.
That sounds like an expensive job. A coin meter sounds more expensive than smart meters on each socket.
Even adiabatic is useless in my case because the guy would use constant heater anyway, let’s not question why.
I don’t hear my room and I have proper bedding.
The numbers are accurate, tho I don’t see how my explanation would solve my problem SparkyChick
I don’t see how your figures can be accurate.
How do you wash, make hot drinks, cook food, keep food cold ...,,
These all add up
So stop messing around and convince us you know your figures..
How much do the winter months compare with the summer?
Is that the same thing as a Landlord’s meter?
Back in the past you could buy a meter that you owned and could install per room.
Newer version then the twister type,
These all add up
Ty. I will look at installing a digital meter like how a coin meter used to be installed.
@David Mack ,
Looks like you've got an answer you're happy with.
I'll say thank you on behalf of all the members you've insulted along the way and leave you with a warning... if you post again and display a similar level of contempt for the people who are trying to help you, I'll personally ban you. Whilst there is a certain level of chit chat between the professional members, the majority of members time here is spent answering queries from other electricians and members of the public. We do it for free because we like to help... we don't do it to be insulted.
Merry Christmas, Happy New Year and welcome to the forums.
Help needed on electricity meter
Deleted member 114336,
SparkyChick,
