C
celticjam
Hi, I just wanted to replace my light switch with an infrared module. The wiring in the switch was just Live and Neutral (1-way switching). I attached them to the infrared switch (which only has live and neutral points). The switch works, but all it does is dim the lights and the extractor fan stays on permanent live. Is this a problem due to the low voltage lighting or the circuit? I believe that I will have to rewire the ring into the switch directly to get it to work. Could you advise on the best way to wire the circuit? I attach a diagram of the junction box with the 1,2,3,4 a & b being the connection points in the box.
Thanks in advance for any advice you can offer?
