V
vickery1971
Hello again, as usual I need some advice from the learned amongst us. I went to a job today with the customer saying he was reading a book and the RCD tripped. When I got there he had sussed that it was the RFC in his flat and had turned that circuit off. I unplugged all appliances and it was still tripping. I then began to check the circuit out to check for a faulty socket or water ingress. To cut a long story short I ended up sussing that the RCD stays on until it is under load, it seems that the oven circuit (on its own circuit and working fine with the oven) but if you plug any appliance into the cooker switch it trips as soon as there is a load. I then thought it may be the RCD. When I tested the RCD I got >51ma on a ramp test and 1x >40 and 5x >400. I then changed the RCD for a new one and got the same readings. I have tested with all loads disconnected and still the same.
Answers on a postcard
