HELP needed with Electric/Fuse box | Page 2 | on ElectriciansForums
Discuss HELP needed with Electric/Fuse box in the DIY Electrical Advice area at ElectriciansForums.net
If that is not the DNO meter then yes it can be changed by the electrician but that looks very much like a DNO meter not a private one as we wouldn't install a cutout like that to fit a private meter
If its a block of flats etc, there may be a main intake position on the ground floor. DNO may have basically a splitter box there which in turns feed each flat. At the end of day, it's the DNO to speak to.
if DNO are saying that it's an electrician's job, it sounds like it's driverman's explanation and that is a secondary cut-out.
Just to confirm...If the meter belongs to the supplier, then the cable as I see it belongs to the DNO.
Reply to HELP needed with Electric/Fuse box in the DIY Electrical Advice area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E. Kitchen is being...
