Help needed with photocell problem | on ElectriciansForums
Discuss Help needed with photocell problem in the Australia area at ElectriciansForums.net
baza
I need to add a override switch to a Photocell controlling a light. My thoughts is to use a one gang two way switch to switch between a live feed to light and live feed to the photocell, the only problem i can see is in doing this, is the switch live terminal of the photocell will be live when the photocell is overrided, could this possibly damage the photocell
Any help would be much appreciated
Reply to Help needed with photocell problem in the Australia area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
