Help.. no lights downstairs in my home | Page 3 | on ElectriciansForums
Discuss Help.. no lights downstairs in my home in the UK Electrical Forum area at ElectriciansForums.net
jrt
Southampton
Hope someone can please help with strange (to me) issue
I turned lights in last night in my home & they came on & then went off. But all apart from 1 light downstairs in my house doesn't work. At first I thought fuse, but it's ok. The 1 light that stays on is on same fuse as the ones that won't. None are linked with same switch so none of the lounge, kitchen, dining room, hall or lower toilet are working. Any ideas on where to start to remedy ?
Morning, thanks for all the comments. I have a switchbox (not breaker) that has fuses in it that has 5 fuses in it, 2 for lights (up/down) 2 for sockets (U/D) & 1 for the cooker. If I swap the fuses for lights, all still work upstairs so thats how I know fuses ok. The light that works is not closest to fuse box. FB is in a converted garage & the light in that room does not work, in fact, I would say only light that does work is furthest from the FB. Nearly all my lights downstairs are spotlights, I think maybe a loop issue somewhere ? PS: I am in the UK
"If I swap the fuses for lights all still work" are you just swapping the upstairs and downstairs over, have you actually checked to see if the fuse on the circuit that isn't working is OK? Your original post seems to intimate that all the lights are on 1 fuse, in your last post you say you have 2 fuses 1 for up and 1 for down 99% sure 1 of the fuses has blown, time to get your tools out and check the fuses out.
2 fuses, A - Downstairs, B Upstairs. 1 light from A working, all from B working. If I remove fuse B & put in Fuse A slot & A into B, then same result, all up ok, only 1 from down working.
I have now dropped down 20 spotlights & checked all wiring, all ok & tight. I have checked 4 ceiling lights, all ok & tight. I have removed 4 light bulbs, all ok & work in lamps. Nothing on the face of it is wrong, everything "should" work. I have a friend who is going to lend me a multi-meter in a couple of hours, that I suppose is best way to check if I am getting feed ?
You must take care when working /testing on live circuits, especially with a borrowed DIY meter, which I presume what your Friend is, a DIYer.
Test leads need to be up to an industry standard, which your borrowed meter may not conform to, this in its self could be dangerous, I would seriously think again before attempting this, do yourself a big favour and get some professional help, call an Electrician.
No: The best & safest way now is to call a sparky, if you find no feed at some point would you know how to actually locate the fault ?. I'm all for DIY but also for people knowing their limits.
Reply to Help.. no lights downstairs in my home in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
