Help.. no lights downstairs in my home | Page 8 | on ElectriciansForums
Discuss Help.. no lights downstairs in my home in the UK Electrical Forum area at ElectriciansForums.net
jrt
Southampton
Hope someone can please help with strange (to me) issue
I turned lights in last night in my home & they came on & then went off. But all apart from 1 light downstairs in my house doesn't work. At first I thought fuse, but it's ok. The 1 light that stays on is on same fuse as the ones that won't. None are linked with same switch so none of the lounge, kitchen, dining room, hall or lower toilet are working. Any ideas on where to start to remedy ?
Thanks, so the one I posted a pic of should be fine or is that just for looping ?
Im guessing that as I can get lights to all lights from powering externally (use of live in working light to any switch) the worse I have is an incomplete circuit meaning the circuit will just have lower power at the CU ?
I'm all for advanced DIY, as long as you know your limits. Asking questions like you have asked, especially the ones above, shows you are beyond your limits. It's unfortunate you have had a bad experience with the electricians you have had round, but I feel this is the only way to go.
As sais above, you may put a sticking plaster on the fault and get your lights lit, but what dangers have you left and/or created?
Hopefully someone on here will be local to you. I reckon if you show an interest then they will explain to you what the fault was once they have found it.
I love trying to find faults like this. Shame im up in the lake district.
This is exactly why we always wire our mains to the switches. So much easier to fault find. Again if its loop in at the light should be easy to find too, unless someone has been putting joint boxes on inaccessible places. Cant see it being the cable damaged (unless some one has been unlucky and nicked the cable with a screw) more likely to be a failed joint. A decent electrician should be able to pinpoint the fault quickly. Might take time to rectify though depending on whats found.
Ps are you sure its loop in at the light and u dont have live and neutrals at the switches?
Picture inside light housing that works
[ElectriciansForums.net] Help.. no lights downstairs in my home
So its loop in at the light done very badly. Get rid of the wago conector on the lives (red) and put a 15amp connector (like the one on the neutrals) on it then you know all lives are making a contact
FFS why????
nothing wrong with those wagos except for the invisible enclosure. when you find it, it should look like this:
Yes they are great when used correctly.
Only asked him to use 15amp connector cause hard to get them wrong. Looking at the photo he has live in and two live outs so (not including the one to the switch) so problem has to be there unless both lives out have a fault
Reply to Help.. no lights downstairs in my home in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
