J
jules27
Just an enquiry Does a mobile dist board need a Periodic?
Hello there ,
Hope someone can help? I recently PAT tested A mobile exhibitions kit( contained loads 16a extension leads , air blowers for the big inflatable work lights etc) , in this kit they had two dist. boards which get connected to either a 2k genny or a 230 supply at varying locations . For the d.bs Is it satisfactory to test between S/outlets and earth bar For earth cont etc ,or does it require a periodic ?which i know i cant do as im not 2391 etc............ thanks
I know the installation should be tested after each use .....but i am a little unsure , as i have advised this is possibly the case , cheers.......anyone help??
Hello there ,
