Help. Outdoor light wiring? | on ElectriciansForums
Discuss Help. Outdoor light wiring? in the UK Electrical Forum area at ElectriciansForums.net
Ohio
Hello. The two screws connect a wire that leads outside and ends, I think it used to have outdoor lights.
What kind of lights would I buy to fit this breaker and replace the empty wire?
Thank you so much, this is my Aunts house and I'm trying to help her out!
  • [ElectriciansForums.net] Help. Outdoor light wiring?
that's a timer, and by the looks of the exposed terminals, appears to have a transformer built in, so lights would beed to be 12V or maybe 24V. best get an electrician in to sort it.
Reply to Help. Outdoor light wiring? in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
