*help please*2 way switching landing lighting | Page 2 | on ElectriciansForums
Discuss *help please*2 way switching landing lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sorry guys, switches have been untouched certainly the faults inside downstairs landing light. but god knows where
right. start with the light that has the most wires in. split them up then bell out the cable to the other light. mark it and ignore for now. then get the first light working. once that's done, just parallel up the other light.
like I said I have done all that and identified everything then all I seem to get is either 2 way switching working fine and all downstairs lights and no power upstairs or no 2 way switching and everything else working
So post a diagram of the cables and connections you have identified
only way to do it is go to basics. start at the beginning, ID all cables, draw out a diagram if it helps.
Disconnect everything on the circuit, meter out wire by wire, ferrule every wire, make a drawing and connect as required to get the circuit working correctly, then post back on here to let us know what your mate had done to cock it all up.................
- - - Updated - - -
I was a bit late
Reply to *help please*2 way switching landing lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There may be an earth wire in the incoming cable connected to the back box, reading a few clues in what I can see, this wiring looks to date from...
Thanks again for your help, now solved 👍
