A
Arthur Lee
Hi Everyone
I'm new here and this is my first post. I do hope you can help.
I have a Built In Siemens Electrogerate 900W microwave that came fitted with a new kitchen 8 years ago. The model is HF17055GB/02. To be fair it's served me well and I have had no real problems with it - until this morning.
I put my dish of porridge on the turntable, shut the door, selected the 900w setting, timed it for 2 minutes, pressed 'start' and went to put the kettle on. After about 20 seconds, the microwave stopped and the timer reverted to what was the current time. I tried this a couple of more times with the same result. Then I tried the setting on 90W, timed for a minute. It completed the minute without stopping. Then I tried the setting on 180W for a minute. This time, it stopped after 40 seconds.
Observations - Everything works when I press 'start'. The turntable revolves, the light comes on etc.
As an aside, over the past few days, when pressing the button to open the door, it intermittently hasn't engaged first time but always eventually opens. I have checked the hook catches on the door and they're fine. I checked the catch recesses (where the catches go into) and, with the door open, when I press 'open' I have noticed that, in the bottom catch recess, a small fitment rises to the middle. However, on the top catch recess, this fitment doesn't appear. The door itself works perfectly normally, ie when I shut it, it 'clicks' into the shut position.
Not being familiar with the workings of electrical appliances I hope I have explained the problem in a way that's understandable.
Any help would be greatly appreciated. Many thanks in advance.
