Hi Trainees. I'd like some help please with an existing bollard light circuit at one of my clients.
I'll give you some history first. Initially the client wanted a circuit of bollard lights between two buildings on the same property. The 150 meter circuit was supplied from an existing outdoor power kiosk and run entirely in 2.5mm by 4-core SWA with the armour used as CPC. At the first and last bollard there was a 2-way switch installed.
The original arrangement looked something like this;
Sure enough, a year later they wanted a second, completely separate run of bollard lights to continue up another path. This circuit was installed very similar to the original circuit and was supplied from a sub-DB in the middle of the circuit and also had a 2-way switch at each end.
