Help please | on ElectriciansForums
Discuss Help please in the Australia area at ElectriciansForums.net
L
lee sandland
Hi all,
i am doing a domestic electrical installer eal level 2 course with olci and came across a question "if i had to wire a immersion heater 10meters away from the cu would i use 11 meters of cable and would i use the same cable size for a 8kw shower
No and No
How long is a bit of string (CABLE) it depends on what, how and where it needs to run.
3kw/230=13.04 amps
8kw/230=34.8 amps
You look at installation methods and let us know what cable sizes you think.
The other things to bear in mind is heat resistant flex for the heater side of circuit and I think the power triangle calculation for emersion heaters is based on 240v so it comes in under 13 amp (May be wrong)
Sorry Lee, I dont understand the 10M/11M bit of the question, If you were to wire mine here at home it is about 8 meters from the CU but you would probably need 16M of cable to get there
What sort of question is that for them to ask you? Do you get any more options for your answer?
hi dave ,i will right you the question
"Make a material list of all the components and accessories necessary to install the following circuit:
1) 3kw immertion heater circuit, 10 meters from the cu
2) 8kw electric shower circuit , 15 meters from the cu
Easy peasey lemon squezy mate. They are exploring loads of your knowledge here, Cookers and Immersions go on their own circuits. Average immersion is 3KW, so its 2.5 to a fused switch, then a meter or so of heat resistant to the immersion. All goes back to a 16 or 20 amp MCB. The cable length written into the question could be about voltage drop, but not even a consideration at 10-11 meters, the Wire size is to be able to carry the current for the load (immersion) the MCB size is to protect the wire from catching fire in an overcurrent situation.
Any suggestion of bogging into the shower circuit is out because both have their own circuit back to the board. If they are suggesting can you use wire big enough to draw 8.5 kilowatts down it for the immersion yes you can, as it only draws 3kw.
These questions are easy if when designing, you start with the load and design a circuit for it, right back to the board, learn which circuits have to stand alone. This question is all about watts dived by volts equals amps, and loads of regs.
Well now you've actually posted the question being asked, it make sense now.
Reply to Help please in the Australia area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
