Hi guys, I would very much appreciate some advice here!! Basically was called to a school, every time they clicked the light switch, the RCD in the CU tripped. Meggered the circuit L to E over 299 ohms, E to N, over 299 ohms, but L to N 0.01 ohms. This is correct on a lighting circuit with fluorescent fittings. R1, R2 values all good. This leads me to the conclusion that one of the flo. fittings has become faulty (possibly a small amount of current leaking through to the cpc inside the fitting? But if that was the case, wouldnt that show up on the megger test? When i disconnected the cpc from the CU on that circuit, the lights stayed on! How is the best way to discover the faulty fitting? A lot of head scratching going on today!!!! Any help greatly appreciated, thank you guys.
