Help r2 problems | on ElectriciansForums
Discuss Help r2 problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
brightspark08
Hi all just after a little help here,
Took on a job which another spark started and didnt finish in a kitchen,
Tested ring r1 r2 rn only as I had to shoot off, gonna carry on testing tomorrow
r1 0.28
r2 0.03
rn 0.28
im trying to determine why the earth is so low any help would be great as i have never come across this b4 ring is 2.5 with 1.5 earth
Thanks in advance
Test R1+R2 at each socket should have continuous/same readings apart from spurs......
As long as the Zs is low enough just Make a note on the cert that CPC has parallel path
this is a job that needs sorting. he needs to get to the bottom of this, as the bishop said to the actress, bending her over the table.
You took on a job another spark walked away from...was he a spark?
What im saying is : Does everything look in good nick? If theres been a DIY monstrosity let loose then the parallel path could literally be anywhere.
Could be loose connections aswell at several back boxes, make sure everything is nice and tight. Hope you get to the bottom of it, but as said - it definitley needs investigating/sorting out.
Reply to Help r2 problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
Low pressure mixer spray tap recommendations ? I'll be installing a new kitchen, DIY, and the Mrs wants a mixer tap with a switchable...
Splitty
