Over to you Michelle
You are welcome, that' why we (the electricians forum) are here for.Thank you for your help....
lesson to self "find the forum first and seek advice prior to... not for mop-up"
How long ago was the work actually done?
Part-p certificates can take a couple of weeks to arrive in the post.
but looking at the certificate you do have it doesn't look very professional.
I am in malvern if you would like to get it checked over.
I am a qualified electrician and Electrical contracting is my only trade.
I am also part-p registered (because I have to be)
Just been on to Citizens Advice Consumer Direct, they have advised me to ring the NICEIC to see if he is registered. I 'know' he isn't but it will be good to get it confirmed. Next I need to get a registered electrician to check and certify (read into that rip it out and do it properly) so I will go through the proper channels and then seek to get it sorted professionally.
What the hell has the brand / format of the certificate got to do with anything ?
The only thing important is the information on it.
I use the standard IET certs printed off the computer and then hand filled in because buying booklets all the time costs a fortune , clearly this make me a cowboy.
Lost count number of the times i've seen fancy NIC certs that are pure garbage.
