HELP - simple question, please keep it simple | on ElectriciansForums
Discuss HELP - simple question, please keep it simple in the The Welcome Forum area at ElectriciansForums.net
Jarvio
Mansfield, Notts
I am not an electrician. I joined because I have a simple question.
There is a power outlet in my living room, which has 2 plug sockets. Let's call this power outlet A.
There is another power outlet in my living room, about a meter or so away from power outlet A. Let's call this one power outlet B.
Power outlet A might have a problem, but I am not sure if it does or not.
As a precaution, I removed everything from power outlet A and plugged it all into power outlet B.
My question - IF power outlet A did indeed have a problem, would this problem also apply to power outlet B? I ask because they are in the same room, only a meter or 2 apart, even though they are separate outlets.
Hi J, and welcome to the Forum!
It's possible that B may be ok (if A has a problem with the actual outlet, say) or B may have the same problem as it may be on the same cable as A (if it was a cable fault).
Can you tell us any symptoms?
A games console turns off by itself. However, I know it is not an issue with the console, because I had it replaced with a brand new one, which does the exact same issue.
It's not a common issue, but it happens, and it makes my gaming experience hell because I'm constantly worrying that it will switch off mid-game.
The fact that this issue happened again when the console was replaced, tells me that it is something in my house that is causing the issue.
To my knowledge, this has not happened on any other devices. However, I am highly confused as to what caused this issue, and nobody could help me. That's why I am asking here, and wondering if it is the power outlet.
But as the 1st reply said, the 2nd power outlet could have the same issue, so I don't know what to do anymore.
How do I do this, who do I contact?
Well if you are concerned Jarvio, contact an Electrician, you should be able to find someone suitable on line, obviously pick someone from your area/location, get several quotations and it's not always best to pick the cheapest, look for referrals from previous customers, I would say pick a trades person who belongs to one of the CPS schemes, but not all are as they seem, I'm afraid you will have to use your own judgement, a sad reelection on our trade I'm sorry to say, but good luck and I hope you get your problem sorted.
Thanks. Before I saw your message, I emailed my energy provider - do you think they'd be able to send an electrician?
Have you tried something else in the socket? I don't think you've mentioned. Seems odd (to me) to go straight for dismantling the socket when the only thing to go wrong is a computer console.
Separately, it sounds to me like a thermal cut out on the console. Make sure the area it is in has some form of through ventilation, it might help.
EDIT: Ah. Des has beat me to it...
I have tried the console in both the 2 different sockets of outlet A. It has the same issue in each.
Everything 'works' in both sockets, but the issue with the console is an unpredictable and rare issue that cannot be tested at all, so it is absolutely impossible to tell if any other devices are affected. This is the problem.
This is why I am questioning the outlet itself, or whatever. I know nothing about this stuff. And I don't know what to do. It's giving me a breakdown.
And no, the console isn't on a carpet or cupboard.
Reply to HELP - simple question, please keep it simple in the The Welcome Forum area at ElectriciansForums.net
The best and easiest way to do it would be turn off the power and take the light switch out and splice the 2 wires on the switch together. Your...
