HELP - simple question, please keep it simple | Page 2 | on ElectriciansForums
Discuss HELP - simple question, please keep it simple in the The Welcome Forum area at ElectriciansForums.net
It's giving me a breakdown.
Steady on there Jarvio :eek: Clair Voiant is coming on later,she will see what is the problem
Des who is clairvoyant, if I maybe so bold?
First question for me is what is the brand of console, many things can shut a console down or put it into sleep mode, these could be software conflicts in the games or ambient temp' been too high and the console getting to hot.. if you have indeed replaced the console I assume you played the same games on it which means you cannot assume their is a power point issue here, if your power supply had a mains transient (surge or volts drop) then it would have to be for a duration that you would notice with other items like your TV,lighting etc as most modern electronics have inbuilt smoothing filters that allow for a short transient but like anything they will be effected if it is a lengthy issue like a few seconds.
Okay, here's a straight-forward follow up question.
When the console powers off, do you have to reset any circuit breakers in the board? If no, it makes it less likely that there is a problem with the actual stuff on/in the wall.
Des's suggestion of putting a table lamp in the other socket is a good one. I'll mean that when it does shut down you can pretty much rule out the wall socket.
Have you tried searching on the internet for overheating problems for your particular console?
EDIT: I need to type faster. Thanks Darkwood!
No, I don't have to do anything with the electrics. I just turn the console back on again, and it works again
When the console turned off, I don't think the TV or any other devices did, I think it was just the console. But my memory is hazy on that, but I don't remember the tv ever switching off with it.
Okay - so like I said earlier, do some research on the type of console. Everything pretty much points to that. As such, I understand your discretion as to it's make. Darkood has talked about the components inside these things to deal with power flucuations - if any of those components are faulty, it could cause the software to shut down. There are many many more components of much greater complexity in your games console than in the power supply!
Best of luck!
Best of luck!
That's the thing, I researched if anyone else had the problem with the console, and nobody had the same issue as me. I then sent it into Nintendo to repair it, they replaced it with a new console, and it did the same thing.
could even be a blip on the supply. we had one a couple ofweeks ago. power went off an dback on within a couple of seconds. wiped out the hard drive on my CCTV.
Reply to HELP - simple question, please keep it simple in the The Welcome Forum area at ElectriciansForums.net
The best and easiest way to do it would be turn off the power and take the light switch out and splice the 2 wires on the switch together. Your...
