help to wire combi boiler for underfloor heating and house radiators | Page 2 | on ElectriciansForums
Discuss help to wire combi boiler for underfloor heating and house radiators in the UK Electrical Forum area at ElectriciansForums.net
aldo95
Hi there. Major cyber pint for anyone that can help me with this problem.
I have a vokera vision c combi boiler( which has volt free connections) that has to do the house radiators and one room for underfloor heating. There is one motorised two port valve for Radiators and one for the underfloor heating. I have a salus two channel programmer to control the house radiators / underfloor heating separately. There's a pump for the underfloor heating and I've also got two bog standard dial room stats(one to control house radiators and one to control the underfloor heating.
If anyone could help and give me the idiots guide to wiring all this up as my head is a bit fried with this
I'm just getting a bit confused with volt free connections at boiler/ then using 230v as well to switch things.
Any help at all would be great, as im under a bit of pressure to get this going.
If you want to insert a pic follow this
  • [ElectriciansForums.net] help to wire combi boiler for underfloor heating and house radiators
I'm a bit muddled after seeing the common thermostat connections, is it all connected in a temporary configuration because it doesn't look right to me. Apologies in advance if I'm wrong!! I've also noticed it says wireless on the control centre, any reason for it?
I meant to say that this wiring centre requires that the room stats send back a wireless signal back to it. The reason that I'm going back to using a joint box method is that The kit didn't come with wireless stats so I was just going to use altech 230v dial ones. All connections at wiring centre are temporary at the moment
easy enough to do.
Reply to help to wire combi boiler for underfloor heating and house radiators in the UK Electrical Forum area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
glad it was such a simple fix..... And good job the previous owners didnt take it with them
