Help understanding 2 way switching. | on ElectriciansForums
Discuss Help understanding 2 way switching. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Inverness
so I understand how 2 way switching works up just needing some help with this. If I have a 2 gang 2 way switch, and I am taking the feed to the switch, do I link out the commons ?
If you google two way switching etc and even look on Youtube there’s loads. Try John Ward or GSH electrical. Make sure you have some brown sleeving for your switched lines. :)
Reply to Help understanding 2 way switching. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
brilliant thanks for your support. Lee
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
