Help what test do you carry out on the off peak ccu | on ElectriciansForums
Discuss Help what test do you carry out on the off peak ccu in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
pembrokeshire, wales
hi what test do you do and how do you put it down on niceic installation certificate for off peak heating (economy 7). They on on the same ccu as the rest of the house but it is a dual feed ccu (2 sets of tails) same main earth
I have done: insulation, R1=R2
thanks!!
2 separate sets of circuit details and test tesults with the headings filled in for each, ie ze, pscc, rcd details, db designation etc.
Sheet(s) 1, shows circuits 1 to 8 for example and sheet(s) 2 shows circuits 9 to whatever.
You have 2 suppplies, 2 main switches etc so basically treat it as 2 dbs.
Boydy
Reply to Help what test do you carry out on the off peak ccu in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
I have a number of Limitations are part of my Testing work in my current role. I test as much as practicable and not down any limitations on a...
