thanks god its working that done the job all il have to do is pull in a 230 supply to the control circuit on the ramp it dont like running off one of the inverter phases
glad its working, as mentioned earlier, your inverter output is not true ac so never try to tap off it, its like a stepped square sine wave, but also you would create an imbalanced load on the output and most likely cause your inverter to trip out.
good luck.
Glad to see its working,should be a parameter which shows the current the motor is pulling, it would be worth while to check the current.
a clamp meter will not give an accurate reading!
help wiring inverter to car ramp
Electrician Talk | All Countries
justin221,
justin221,
