Help with a pump please | on ElectriciansForums
Guest viewing is limited
Discuss Help with a pump please in the UK Electrical Forum area at ElectriciansForums.net
Marvo
Staff member
Mod
Mentor
Supporter
South Africa
Can anyone point me in the right direction please? I'm trying to track down the manufacturer and model range for a water pump. I can tell you it's a 2.5kW 3-phase 400v 50Hz motor and the pump is some type of plastic construction. The application is a commercial factory tunnel washer and it's pumping hot water which is dosed with a mildly aggressive degreasing agent. The head pressure requirement is pretty low, I'd guess at 2 Bar (ish) but the volume is pretty high (suction is approx 2 1/2 inch).
Here's what she looks like....
[ElectriciansForums.net] Help with a pump please
I have seen similar on Jacuzzis ,although not in plastic but stainless instead .
Not sure if that helps , but it may be an alternative ?
Edit ; Just noticed it is 3ph ! I have installed similar on dairy equipment , again in stainless steel .
Thanks for the suggestion. I could probably use a 316 stainless pump but I think most of the hot tub pumps are 304 which probably will get pitted corrosion with the chemicals which are mildly caustic. This one is 2.5kW which is also a bit larger than most spa pumps. I'm hoping to find a like for like replacement which will save me spending half a day underneath it with a TIG welder reconfiguring the stainless suction and discharge pipework.
Reply to Help with a pump please in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
