Help with alarm | on ElectriciansForums
Discuss Help with alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
sparkyb
I installed an alarm system about 4 years ago and everything was fine until about a month ago when the client heard a chirping noise coming from the external bell box, I went around and checked the battery in the panel and it was ok so I set the alarm and it set properly and seemed to be working fine. He called me today again and told me that the external bell was again chirping like a bird. Any ideas what could be wrong.
Thank you
what voltage should i be getting on external bell battery and also panel bell too?
what other tests should be done on annual inspection.
thank you for your help
wasn't there a thread a few months ago about chirping bells. something to do with the extremely low temperatures . forget what it was causing, could be a poor batt. in the panel dragging the 13.6volt supply down.
could be the nicad in the bell box was too cold, so that might be a place to start. take a new bell box batt. and a new panel batt. for starters.
that's defeatist. i would measure the hold off voltage 1st at the panel and then at the sounder .
Reply to Help with alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
Shhh, don't tell the Chinese they want a bit of the action.
