Help with Applying SEG | on ElectriciansForums
Discuss Help with Applying SEG in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
igouli
Suffolk
Good evening, I have recently purchased a new build property and it come with solar panels. The problem i have is finding an Export MPAN.
The builders don't seem to know themselves so any help would be much appreciated!
Reply to Help with Applying SEG in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
Use THWN if it might get wet. These wires are not sunlight (UV) resistant unless marked as such. If it was for mains voltage I gather it wouldn't...
